Discussion topic: No connection to internet
This message was authored by: PaulMS
Broadband not connecting. Two orange lights. Reset hub makes no difference. Tool says it's all fine but it obviously isn't. Phone system simply refers back to tool. What next?  Paul
Re: No connection to internet
@PaulMS
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
Avatar for PaulMS
Thanks. Been through this. Says initially there is a problem then when tested says no problem locally or with system. Internet and voice lights steady orange.
@PaulMS
I would give Sky a call.
150 is the free number to use from a phone that has a Sky mobile sim in it or Sky Talk phone otherwise under "Need more help ?" link at the bottom of the page on this link is the number to call Sky on:
https://www.sky.com/help/home
Try saying nothing when spoken to by the bot.
Avatar for PaulMS
About half our our village has a broadband outage. When i call sky requires me to be at home. I want to report that there is a wider area problem (which there obviously is) but cant!!! All help and contact stuff takes you through online testing (from work) but cant do that from home because the broadband doesnt work!!!
Getting increasingly frustrated
Paul
