Discussion topic: No connection Heaton Bolton
Message posted on 08 Aug 2024 08:37 PM
Hello is anyone else having problems with Internet connection Heaton Area Bolton last few days I also can't get on to test my connection it's saying not available and yes unplugged and reset etc
Message posted on 08 Aug 2024 08:44 PM
Re: No connection Heaton Bolton
@Bolton33 Are you able to run the tests from the information below?
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Message posted on 08 Aug 2024 09:13 PM
I have no connection but I'm in Devon, I've run the tests but says all ok
Message posted on 08 Aug 2024 09:49 PM
@Lisa197 Was this the service checker that you ran that shows all of your services in a little house in the background?
