Discussion topic: No broadband
This message was authored by: Martin221
No broadband
Yesterday the broadband dropped out at this time, today it has done the same. We currently have no connection again
Re: No broadband
@Martin221
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
