Discussion topic: No broadband
Message posted on 01 Aug 2026 06:53 PM
No broadband
Message posted on 01 Aug 2026 06:57 PM - last edited: 01 Aug 2026 07:00 PM
Re: No broadband
@Christopherjesusc
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
Edit: your 2 duplicate threads have been removed.
