Discussion topic: No broadband
This message was authored by: Jpartington
No broadband
I have no broadband , I've tried your online service checker it says no issue , I've tried phoning to speak to someone but that's clearly impossible. I've tried all the troubleshooting options available and nothing is working ?
Re: No broadband
@Jpartington
You aren’t actually contacting Sky by posting here as this is a customer ▶️ customer discussion forum where we try to assist other customers.
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
