Discussion topic: No broadband
This message was authored by: Roger1816
No broadband
Exactly that as above. No broadband but your system says that it is working correctly, BUT it isn't. Solve my problem promptly please
Re: No broadband
@Roger1816
You may not be aware but you haven’t contacted Sky by posting here. This is primarily a customer ▶️ customer discussion forum where we try to assist other customers.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
