Discussion topic: No broadband
Message posted on 26 Apr 2026 10:59 AM
No broadband
I currently have no broadband.
i have followed the process and checked the line and it comes back as working ok. I have reset my router and still nothing.
I can connect my devices to the wifi network but all devices say no internet connection. My router has the internet light showing green so no idea what to try next?
Message posted on 26 Apr 2026 11:10 AM
Re: No broadband
@Rus4
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
