11
This discussion topic has been answered Discussion topic: No broadband
This message was authored by: TonyCoad
No broadband
No connection and thw router is flashing green
Re: No broadband
@TonyCoad @Tsimeone
Any broadband issues between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
This message was authored by: Tsimeone
Re: No broadband
Same here... m13 Manchester
Re: No broadband
@TonyCoad @Tsimeone
Re: No broadband
Thank you. It did come back online half an hour later. I forgot to update the reply
This message was authored by: Richl12
Re: No broadband
I've been having problems with slow speeds all week.
Re: No broadband
@Richl12
If the broadband has become slow see this link
Avatar for TonyCoad
Re: No broadband
Came back about 2am?!
Re: No broadband
@TonyCoad typically that means the outage was caused by maintenance activity
This message was authored by: Bb55
Re: No broadband
I have no broadband I have two green and one red on my router
Re: No broadband
@Bb55
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
This message was authored by: Joshy2
Re: No broadband
Broadband keeps dropping out all day everyday for the last week or so can watch TV on my sky q mini box in bedroom as a result of broadband dropping out
Re: No broadband
@Joshy2
See the post above by @Daniel0210 as it applies to you as well.
