Discussion topic: No broadband
Message posted on 02 Mar 2026 11:14 PM
No broadband
Message posted on 02 Mar 2026 11:31 PM
Re: No broadband
Mine's out, I'm in Argyll. The checker says all well, but it's not!
Message posted on 02 Mar 2026 11:52 PM
Re: No broadband
In Argyll too. Having the same problems
Message posted on 02 Mar 2026 11:55 PM
Re: No broadband
That's reassuring! I'm in Kintyre so services a bit dodgy.
Message posted on 03 Mar 2026 12:01 AM
Re: No broadband
Im argyll too and been off for last 40 mins , sky app sayin no problems too!
Message posted on 03 Mar 2026 12:12 AM
Re: No broadband
Mine is out too, Isle Of Arran. Service says no problems but but there clearly is. Green light flashing for 25 minutes now after resetting it 3-4 times
Message posted on 03 Mar 2026 12:29 AM
Re: No broadband
Message posted on 03 Mar 2026 12:33 AM
Re: No broadband
I have just unplugged for 1 min and switched bk on , same prob so pressed and held the reset button for 20 seconds and everything seems to okay (well for now) worth a try people. 👍🏼
Message posted on 03 Mar 2026 12:37 AM
Re: No broadband
Message posted on 03 Mar 2026 12:39 AM
Re: No broadband
Message posted on 03 Mar 2026 12:42 AM
Re: No broadband
Ah sorry it didnt work for you, hope its back on soon... skys getting really poor with their service these days time for a change i think for me.
Message posted on 03 Mar 2026 03:04 AM
Re: No broadband
Same issue here for me. Flashing green light and no internet for almost 1 hour. Durham area
Message posted on 03 Mar 2026 05:25 AM
Re: No broadband
For those of you having an issue before midnight this link provides information about the coloured lights you may see on the various hubs https://www.sky.com/help/articles/hub-lights-explained-start
For those with issues starting between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or try the advice given at the start of my post.
