Discussion topic: No broadband
This message was authored by: Jnk123
Message posted on 01 Mar 2026 06:36 PM
No broadband
For three past 3 weeks ive had very limited broadband sometimes not working at all for periods, tried everything on the fix it pages and everything else and still next to nothing
Message posted on 01 Mar 2026 06:44 PM
Re: No broadband
@Jnk123 Use the sky help below.
Try running the line test here to see if any faults are found:
