Discussion topic: No broadband
Message posted on 02 Feb 2026 04:27 PM
No broadband
I have no broadband despite testing site saying I have. No broadband light on city fibre box
Message posted on 02 Feb 2026 04:35 PM
Re: No broadband
@Martin1872
