Discussion topic: No broadband
This message was authored by: Seahorse6263
No broadband
No broadband in Cornwall
Re: No broadband
@Seahorse6263
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them so they can look in to this for you.
This message was authored by: Lillex
Re: No broadband
Just a warning - you have to phone and immediately report the outage otherwise they will not give you compensation even though their app tells you 'we know there's an outage in your area you don't need to do anything'. We were without internet for a week and they offered us £3.06 in compensation despite Ofcom's automatic compensation being £9.98 per day. Their advice on the app is misleading.
Re: No broadband
@Lillex
This link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it.
From Ofcom’s website:~
If your broadband or landline service stops working, you will have to report the fault to your provider. If the service is not fixed after two full working days, you would not need to ask for compensation or contact your provider again, as your provider has systems in place that mean you will start receiving compensation automatically if the repair takes too long.
This auto compensation is applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from 01/04/25 the new rates are £9.98 per day)
▫️There is no equivalent scheme in place for customers in the Republic of Ireland.
▫️There is no automatic compensation for TV services affected by a broadband problem.
▫️Sky broadband being discussed here is a domestic service therefore whilst it's fine for customers who work from home to use it for that purpose they won't receive additional or quicker support.
Re: No broadband
I understand how the ofcom system works - but unfortunately they have not honoured it
Re: No broadband
Then complain and take the matter to ombudsman services if they haven't complied.
