Discussion topic: No broadband
Message posted on 04 Jan 2026 11:49 AM
No broadband
There is no broadband, the middle light on the router keeps flashing orange then goes off
Message posted on 04 Jan 2026 12:03 PM
Re: No broadband
@BigAl61 About the lights below, but the hub is struggling to connect to the Internet for some reason!
Try running the line test here to see if any faults are found:
and
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
