Discussion topic: No broadband
This message was authored by: Neil123456
No broadband
Hi, the second light on. Our hub is orange not green.  The system check say everything is working but we have no internet at all
Re: No broadband
@Neil123456
As it's a weekend it's probably not maintenance taking place.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
