1
This discussion topic has been answered Discussion topic: No broadband
This message was authored by: Charlotte3Bs
No broadband
No broadband have reset router and switch off b9x
Re: No broadband
@Charlotte3Bs
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Re: No broadband
@Charlotte3Bs
