Discussion topic: No broadband
Message posted on 23 Nov 2025 04:41 PM
No broadband
WiFi has suddenly gone off done all the step by step an test show it's working but slower than normal hub light is red?
Message posted on 23 Nov 2025 04:46 PM
Re: No broadband
@Jackie3564
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
