Discussion topic: No broadband
This message was authored by: Joannebowles
No broadband
We recently had our broadband updated and it keeps failing
im really unhappy with this - never had a problem prior to upgrade
the box is only showing two green lights - should be three
I've been with Sky for over 20 years and expected better
I look forward to hearing from you
jo
Re: No broadband
@Joannebowles
This is a customer ➡️ customer discussion forum where we try to help other Sky customers. You aren’t speaking to Sky staff by posting on here.
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
Re: No broadband
@Joannebowles  You're not contacting Sky customer services, this is a customer helps customer community, Sky won't respond to your post.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Re: No broadband
@Joannebowles Why only three lights do you not also have a landline voice service with a digital delivery to it?
