Discussion topic: No broadband
Message posted on 01 Oct 2025 10:33 AM
No broadband
My broadband is down this morning, I would like this resolved soon please. When I go onto the checker on the app it said it was working but it's definitely not. Even said it was working when it was switched off.
Message posted on 01 Oct 2025 10:35 AM
Re: No broadband
Hi @Kirsty152
Have the lights on your hub changed at all? The Sky checker should pick things up if your hub has lost connection. Your only other option would be to call Sky
Message posted on 01 Oct 2025 10:38 AM
Re: No broadband
Yes I only have two lights on rather than the normal 3
Message posted on 01 Oct 2025 10:59 AM
Re: No broadband
@Kirsty152 See the link's below they may be off help, and if you do need to run / test would be over mobile data as your System may not be connected!.
Message posted on 01 Oct 2025 11:33 AM
Re: No broadband
Hi @Kirsty152
In that case I would call Sky and report a line fault.
