Discussion topic: No broadband
Message posted on 11 Sep 2025 03:11 PM
No broadband
I have no broadband connection
Message posted on 11 Sep 2025 03:16 PM
Re: No broadband
No as I still have no broadband
Message posted on 11 Sep 2025 03:22 PM
Re: No broadband
@Jacs631
Not sure who or what you're referencing in your second post?
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
