Discussion topic: No broadband
Message posted on 05 Sep 2025 08:14 PM
No broadband
No broadband since yesterday . It crashed and haven't been able to reconnect since
Message posted on 05 Sep 2025 08:23 PM
Re: No broadband
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
