Discussion topic: No broadband
This message was authored by: Jodiefleet
No broadband
My broad band went off today about 1pm. I only have 1 orange light that says voice. Workman have been down my road so could be due to that. I have reset it but nothing changes
Re: No broadband
@Jodiefleet
