Discussion topic: No broadband
This message was authored by: QueenTup
No broadband
No internet connection on devices or television.  Orange lights on modem despite app saying it's checked all devices & WiFi and all is ok.  Not sure how you check but it's inaccurate as I can confirm I don't have any connection
Re: No broadband
@QueenTup
Avatar for QueenTup
Re: No broadband
Thanks very much for the reply, I'll try all the suggestions now.
This message was authored by: SueJ221
Re: No broadband
I'm getting exactly the same thing ☹️
