Discussion topic: No broadband
This message was authored by: Kyronp1818
No broadband
Since around 11am this morning our broadband has been out. Have rebooted but still no luck. Got one light which goes green then red.
Re: No broadband
@Kyronp1818
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
