Discussion topic: No broadband
This message was authored by: Markscott
No broadband
I have no broadband at home , there is no lights on the router i have tried switching it off, i'm at work and my wife is at home.Would it be possible to give her a ring and sort this out?She needs it for work thanks
Re: No broadband
@Markscott
This is a customer helps customer forum and you aren’t contacting Sky Customer Services on here. Sky won't call you or your wife.
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
