Discussion topic: No broadband since went down 17 Dec 2025
Message posted on 18 Dec 2025 02:45 AM
Broadband has been out since last night. Sky app recognises there's a red exclamation beside all features, but when you run their test it says everything is ok. It's definitely not. It's completely down, despite three green lights on the hub.
Message posted on 18 Dec 2025 04:50 AM
Re: No broadband since went down 17 Dec 2025
@Shaddowe
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
