Discussion topic: No broadband or phone
This message was authored by: Kpb12
I have arrived home to find no broadband or phone working just a white light on the router ?
Re: No broadband or phone
@Kpb12
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
