Discussion topic: No broadband or phone like but says it’s ok?
Message posted on 23 Jan 2025 04:32 PM
My phone line has just gone down.
have 3 lights. Last one is orange on hub box.
no lights on outreach box.
but checks say all is ok?
Message posted on 23 Jan 2025 04:37 PM
Re: No broadband or phone like but says it’s ok?
@ashcatt
