Discussion topic: No broadband ever though your check says it’s okay
Message posted on 02 Dec 2025 03:57 PM
I have followed your instructions and turned everything off waited a few minutes then turned it back on but I have no lights on my router.
yet when I use your test it says everything is okay.
can you explain please
Message posted on 02 Dec 2025 04:03 PM
Re: No broadband ever though your check says it’s okay
@Cpl887mcd
I’m afraid you aren’t communicating with Sky by posting here. We are customers on a customer ➡️ customer discussion forum where we try to help other Sky customers.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
