Discussion topic: No broadband connection
This message was authored by: Babydebs
My Internet dropped at 9.20. I have tried switching off at the wall many times. The box on my wall is showing a red light. Tried service checker over 50 times and shows everything as fine but that can't be because there is no broadband and my hub has been unplugged. Ive tried all the help but nothing has worked. Please help!
Re: No broadband connection
@Babydebs
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
