1
This discussion topic has been answered Discussion topic: No broadband connection
This message was authored by: NH16
We have no broadband connection please can you help
Re: No broadband connection
@NH16
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
▪️I AM NOT A SKY EMPLOYEE ▪️
@NH16
