Discussion topic: No broadband connection
This message was authored by: ethleen
The LOS light is red
Re: No broadband connection
@ethleen
As you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
Avatar for ethleen
Thanks- I called Sky up and they went through some trouble shooting with me but still not resolved. I'm currently waiting on an engineer from open reach to attend today,
