Discussion topic: No broadband connection
This message was authored by: Tracy1651
Broadband connection
Re: No broadband connection
@Tracy1651 Did you ever have a connection, your posting has zero information!
This message was authored by: Lesl2
Spoke to sky earlier on the evening about the landline. Since the I have just tried to go onto broadband and there is now no connection. I have followed the instructions to connect but that has not worked. It was working until previous to my earlier phone call
@Lesl2
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
