Discussion topic: No broadband and red light.
Message posted on 22 May 2026 03:31 PM
I have a red light and no broadband.
Message posted on 22 May 2026 03:35 PM
Re: No broadband and red light.
@Hbish93
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Message posted on 22 May 2026 04:11 PM
Message posted on 22 May 2026 04:14 PM
Note the reply above especially the second paragraph.
