Discussion topic: No broadband again
Message posted on 09 Jul 2026 04:42 PM
No broadband again
Since fibre was installed there have been issues. I was assured it was resolved yet it is off again
Message posted on 09 Jul 2026 04:46 PM
Re: No broadband again
@Chris_666
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 09 Jul 2026 04:59 PM
What lights are lit (or not) on your broadband hub ?
Message posted on 09 Jul 2026 05:14 PM
Our broadband seems to be going off every afternoon and doesn't come back on until sometime in the early hours of the morning 🤨
Message posted on 10 Jul 2026 12:30 PM
Says everything about customer service, this message was sent to their online chat
Message posted on 10 Jul 2026 12:34 PM
That is one of the issues we have had.
Finally got an openreach enginner here rather than a sub contractor, he found the fault in 5 minutes.
There was a micro crack in the fibre running to the house from the pole.The issue I told was where I told sky it was 2 weeks ago
