Discussion topic: No broadband again
Message posted on 08 Jul 2026 06:32 PM
No broadband again
Sky broadband and WiFi dropping out consistently
Message posted on 08 Jul 2026 06:39 PM
Re: No broadband again
@Wvsully
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
