Discussion topic: No broadband again
Message posted on 15 Jan 2026 07:47 PM
No broadband again
Had no broadband last week for 3 days and it's now down again **bleep**!!!
Message posted on 15 Jan 2026 07:54 PM
Re: No broadband again
@Denn2
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
Message posted on 15 Jan 2026 08:16 PM
I work from home I need the broadband working I cannot wait two days time to switch providers
Message posted on 15 Jan 2026 08:20 PM
Unless you move to a business subscription which has a better service level agreement you'll probably be in the same position.
