Discussion topic: No broadband 6/01/25
This message was authored by: Katie_D
I have no broadband connection and have followed the steps to restart and it hasn't worked. When I do a service check it says everything looks good, when it clearly isn't as there's no internet! Even the sky q box says there's no connection. Please advise.
Re: No broadband 6/01/25
@Katie_D
The first thing to do is check to see if there are any outages nearby via this link https://www.sky.com/servicechecker
