Discussion topic: No Wifi
Message posted on 08 Jul 2026 01:55 PM
No Wifi
No wifi however hub has all 4 green lights
Message posted on 08 Jul 2026 01:57 PM
Re: No Wifi
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
Message posted on 08 Jul 2026 02:02 PM
Re: No Wifi
I have the exact same issue right now. Not sure if something has gone down?
All four lights on the hub fine, rebooted, connections tests online came back ok. No idea what is gpnig on
Message posted on 08 Jul 2026 02:06 PM
Re: No Wifi
I have literally plugged everything out at the mains left for a mi and replugged and happened to fix it
