3
This discussion topic has been answered Discussion topic: No Wifi
This message was authored by: Van74
No Wifi
The router light turns a solid red light after a few seconds. Setting says it's connected to router but can not connect to the internet. It's been down since 11.30am yesterday. Any suggestions please?
Re: No Wifi
@Van74
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: for any customer whose services are restricted due to a missed payment phone contact is unlikely to work.
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note ~ ROI customers 🔹If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
Re: No Wifi
@Van74
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Avatar for Van74
Re: No Wifi
Thank you I have tried this and it says the service is not available. I will give them a call. Do you know the number to call from a mobile?
Re: No Wifi
@Van74
