Discussion topic: No Wifi
Message posted on 17 Apr 2025 05:35 PM
No Wifi
Have been through the troubleshooting guide without a resolution
Message posted on 17 Apr 2025 05:42 PM
Re: No Wifi
@LauraWoods1
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
