Discussion topic: No Wifi -- light off
Message posted on 04 Sep 2026 11:23 AM
Wifi is not working. The internet light is off. I have tried unplugging and plugging back in. The unit is only about a month old and has been working fine until now. Anyone else receiving this error around Lucan, Dublin?
Message posted on 04 Sep 2026 11:29 AM
Re: No Wifi -- light off
@kber
Broadband and Wi-Fi are different. Broadband is the internet connection provided by your ISP (Sky), Wi-Fi is the wireless connection between your hub and devices.
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
