Discussion topic: No Wifi Connection
This message was authored by: DeanaNolte
No Wifi Connection
No WiFi connection at my house  Online checks say it's all good.
Re: No Wifi Connection
@DeanaNolte
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
