Discussion topic: No WiFi
Message posted on 13 Aug 2026 12:04 PM
No WiFi
Our WiFi has been down all morning. We have tried resetting everything and after 2 hours we can not get it back up
Message posted on 13 Aug 2026 12:14 PM
Re: No WiFi
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
Re: No WiFi
@StevieM28
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
