Discussion topic: No WiFi
This message was authored by: Petro37
No WiFi
I have got Sky Max Hub and I have problem with WiFi reaching my bedroom upstairs.
what can I do ?
Re: No WiFi
@Petro37
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
