Discussion topic: No WiFi
Message posted on 14 Jul 2026 11:49 AM
No WiFi
I have no WiFi and haven't for a few days I 've followed all the online instructions. And still no WiFi. Please help
Message posted on 14 Jul 2026 12:12 PM
Re: No WiFi
@Pauline2310
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
