8
This discussion topic has been answered Discussion topic: No WiFi
This message was authored by: Ll2208
No WiFi
Hi our WiFi has gone off. We've done checks and says there's no issues in our area
Re: No WiFi
@Ll2208
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Re: No WiFi
@Ll2208
This message was authored by: ShyGirl15
Re: No WiFi
We have the same issue in Dublin 15 for the past hour. Other neighbours in the area reporting the same. Apparently there is also an issue with virgin.
Re: No WiFi
Just to clarify, My sky tv is working, but our sky broadband WiFi router has no internet connection from the fibre box.
This message was authored by: littlecat
Re: No WiFi
No wifi in cardiff, bern down since 9pm, service checker said a problem, but when you click let's fix it, that says its having issues
Re: No WiFi
@littlecat
What is the result of this line test:
Re: No WiFi
The service checker is working now , says problem outside and book an engineer,  although the local fb page seems to have a lot of people in the same postcode with no sky bb
Re: No WiFi
@littlecat
Once aware Sky usually quote 2 WORKING DAYS as a potential fix time because of the service level agreement in the UK between ISPs and Openreach for fixing a domestic fault.
Some repairs take longer, for example when a pole or cabinet has been damaged or Openreach / City Fibre need to dig the road up (once they’ve obtained permission from the local council).
This link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it.
From Ofcom’s website:~
If your broadband or landline service stops working, you will have to report the fault to your provider. If the service is not fixed after two full working days, you would not need to ask for compensation or contact your provider again, as your provider has systems in place that mean you will start receiving compensation automatically if the repair takes too long.
This auto compensation is applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from April 2026 the rate has increased to £10.34 for every complete day).
▫️There is no equivalent scheme for customers in the Republic of Ireland.
▫️There is no automatic compensation for TV services affected by a broadband fault.
▫️Sky broadband discussed here is a domestic service so whilst Sky allow customers who work from home to use it for that purpose they won't receive additional or quicker support.
Re: No WiFi
Then that is what you need to do as they will go the source of the outage to carry out the repairs.
