Discussion topic: No WiFi
This message was authored by: LL7
No WiFi
No internet since 11am. Musselburgh
Re: No WiFi
@LL7
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
