Discussion topic: No WiFi
Message posted on 11 Jun 2026 01:08 PM
No WiFi
No WiFi
No Internet connection
There was an outage for the last 2 day okay this am
Now no connection sgsin
Message posted on 11 Jun 2026 01:11 PM
Re: No WiFi
@Gio34
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
