Discussion topic: No WiFi
This message was authored by: SM732
No WiFi
yellow/white light pulsing WiFi down since 5pm
Re: No WiFi
@SM732
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
