Discussion topic: No WiFi
This message was authored by: Hi231
No WiFi
I have no WiFi done the usual turned everything off but still nothing. Any advice please?
Re: No WiFi
@Hi231
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
This message was authored by: kevhob
Re: No WiFi
Exactly the same issue. No WiFi from 11pm last night. Router has a green flashing light. Can't get an engineer until Thursday. Not great when you work from home and rely on it
Re: No WiFi
@kevhob
48 hours for an engineer is good. Once aware Sky usually quote 2 WORKING DAYS as a potential fix time due to the service level agreement in the UK between ISPs and Openreach for fixing a fault.
Sky broadband being discussed here is a domestic service therefore whilst it's fine for customers who work from home to use it for that purpose they won't receive additional or quicker support.
Re: No WiFi
WiFi back up after 2 days on its own. Engineer due tomorrow and if I cancel I get charged £25 haha.
